JamesSimpson
May 05, 2024Tutor
Re: Is there any benefit to have a wired backhaul for an Orbi Mesh system?
In my experience no! I’ve had an RBR750 and 5x RBS750s for a couple of years. Although for some of that time I’ve had pretty good Wi-Fi network, I’ve spent countless hours/days/weeks fiddling tryin...
JamesSimpson
May 07, 2024Tutor
I’m sure in general you are correct, wired will usually be more robust than Wi-Fi, which is why I wanted to go down that road in the first place. All I know is that the end result for my network has been very clear. After a huge amount of time and troubleshooting (new cables, setting everything up from scratch etc), the network is significantly more stable with a wireless backhaul. Handoff when roaming between APs works much more smoothly and devices connect much more quickly. I’m not sure why, that’s just my experience. Perhaps I’m just unlucky!
May 07, 2024Guru - Experienced User
Would need more details and feedback on questions given to better help you figure out the "I’m not sure why".
