sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
Mar 16, 2020Guru - Experienced User
What Orbi product model do you have?
Is these over wired or wireless connections?
For wireless, be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
If this still fails, then try this:
sutset
Mar 16, 2020Guide
I have orbi AX started right after firmware upgrade
- FURRYe38Mar 16, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Is these over wired or wireless connections?
- rensulMar 16, 2020Guide
I changed the RTS/CTS values and will update this post on whether it helped. I have wired and wireless clients - both have experienced the problem. I also realize the RTS/CTS value change only affects wireless but I'm trying anything at this point.
I have the RBR 850 and RBS 850 with the router direct to Verizon FIOS - no cable modem. I am positive this is NOT a Verizon issue. As others have pointed out, all my problems started after the latest firmware update.
- TURBOGUARDMar 16, 2020TutorHey guys, update here, I unplugged my RBK852 and hooked up my RB50. Everything has working smoothly for about 4h now, so I say that’s a win! It’s the damn 700dollar system that doesn’t work. Shame
