sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
rensul
Mar 16, 2020Guide
I changed the RTS/CTS values and will update this post on whether it helped. I have wired and wireless clients - both have experienced the problem. I also realize the RTS/CTS value change only affects wireless but I'm trying anything at this point.
I have the RBR 850 and RBS 850 with the router direct to Verizon FIOS - no cable modem. I am positive this is NOT a Verizon issue. As others have pointed out, all my problems started after the latest firmware update.
TURBOGUARD
Mar 16, 2020Tutor
Hey guys, update here, I unplugged my RBK852 and hooked up my RB50. Everything has working smoothly for about 4h now, so I say that’s a win! It’s the damn 700dollar system that doesn’t work. Shame
- sutsetMar 16, 2020Guide
The support team called me today told me they pulled the lasted firmware from the download site. I am reverting back. This company clearly does not understand what QA means. I had asus router for 5 years never had issues and I paid half of what this piece of junk cost. NETGEAR software engineers simply cannot get it right. Very sad.
- Ramboost2000Mar 16, 2020AspirantHave experienced the exact same issue after auto update. Trying now to revert to old firmware.
Thanks for bringing it to Netgears attention.- FURRYe38Mar 16, 2020Guru - Experienced User
Thanks for letting us know. Thanks for being patient while NG works on this.
Sure is odd that some of us have not seeng this since v10.11 appeared for us. Sure would like to know why there is this disparage between some users.
Can you downgrade to v3.1 and see if this helps your system? Others are reporting that downgrading is working for them.
