sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
Ramboost2000
Mar 16, 2020Aspirant
Have experienced the exact same issue after auto update. Trying now to revert to old firmware.
Thanks for bringing it to Netgears attention.
sutset
Mar 16, 2020Guide
My issues are resolved back on the previous version. NG will do this to us over and over. This has been my experience since installing orbi ax. We need a flag to tell the NETGEAR router not to auto update. You can never trust what they are giving you. In this moment of crisis in the USA with all of us working from home the last thing we need is to have them push new software again and have to go to round 2,3,4, x with them again.
- FURRYe38Mar 16, 2020Guru - Experienced User
Glad you got it working.
- tigerisakMar 19, 2020Guide
How do I downgrade? I was given the new beta by Netgear yesterday but has the same issues.
- FURRYe38Mar 19, 2020Guru - Experienced User
You can download files from HG download site and manually install the thru the RBRs web page.
- rensulMar 19, 2020Guide
Unfortunately this has come too late. I had to completely remove my Orbi AX routers and satellites and start using the slower but functioning previous wifi router. I did go so far as downgrading to the previous firmware and still experienced the problems so I invested quite a bit of time to try and stick with this expensive purchase but eventually had to cut my losses and put my old router back in.
Very disappointed.
- TURBOGUARDMar 19, 2020Tutor
Haven't had the time nor energy to downgrade put them back up so still on RBK50. Netgear better fix this asap. It's not cheap (non-working) routers they're selling us!
Did you try a down grade on v3.2.9.2 then re-upgrade to v10.11?
Others are reporting better operation since NG seem to fix issues on there end.
rensul wrote:Unfortunately this has come too late. I had to completely remove my Orbi AX routers and satellites and start using the slower but functioning previous wifi router. I did go so far as downgrading to the previous firmware and still experienced the problems so I invested quite a bit of time to try and stick with this expensive purchase but eventually had to cut my losses and put my old router back in.
Very disappointed.
TURBOGUARD wrote:Haven't had the time nor energy to downgrade put them back up so still on RBK50. Netgear better fix this asap. It's not cheap (non-working) routers they're selling us!
- rensulMar 21, 2020Guide
So after downgrading to the previous firmware and having the same problems, I went back to the V10.11 and did a factory reset as was suggested by FURRY and it's been solid (gaming, netflix streaming, successful Skype for Business test etc.) for the past 6 hours. I really need this to hold so I can continue working from home so PLEASE, PLEASE, PLEASE don't change the firmware again until we get out this crazy health crisis - unless of course it needs to be updated for others (please be sure to test the sh#t out of it though) who may be experiencing problems that I'm not. I don't need any new features - just rock solid fast internet...
I'm also fully aware that all of my optimism could blow up at any time since it's only been 6 hours.
Thanks though for doing whatever was done to make it work (so far).
Rennie
- FURRYe38Mar 21, 2020Guru - Experienced User
Good to hear. Enjoy now. :smileywink:
rensul wrote:So after downgrading to the previous firmware and having the same problems, I went back to the V10.11 and did a factory reset as was suggested by FURRY and it's been solid (gaming, netflix streaming, successful Skype for Business test etc.) for the past 6 hours. I really need this to hold so I can continue working from home so PLEASE, PLEASE, PLEASE don't change the firmware again until we get out this crazy health crisis - unless of course it needs to be updated for others (please be sure to test the sh#t out of it though) who may be experiencing problems that I'm not. I don't need any new features - just rock solid fast internet...
Rennie
- Retired_MemberApr 09, 2020How do I downgrade to resolve problems listed above? Need step by step. MS Teams video conf keeps crashing when using TEAMS for Mac.
- FURRYe38Apr 09, 2020Guru - Experienced User
What FW version is currently loaded?
Did you review the prior post about downgrading to a lower version then back to v10.11?
"So after downgrading to the previous firmware and having the same problems, I went back to the V10.11 and did a factory reset as was suggested by FURRY and it's been solid (gaming, netflix streaming, successful Skype for Business test etc.)"
Does this crash only happen on Mac?
Try different PC or Windows PC to see if same thing happens?
Did this happen before?
Does this happen on a wired and wireless connection?
You should look at the Mac logs or app logs and contact MS support for help and information regarding there app crashing.
Retired_Member wrote:
How do I downgrade to resolve problems listed above? Need step by step. MS Teams video conf keeps crashing when using TEAMS for Mac. - Retired_MemberApr 09, 2020
thanks for the direction. high 5.
And he closes his account. Must have been a mis-configuration.
Enjoy. :smileywink:
