sutset
Mar 16, 2020Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no w...
rensul
Mar 19, 2020Guide
Unfortunately this has come too late. I had to completely remove my Orbi AX routers and satellites and start using the slower but functioning previous wifi router. I did go so far as downgrading to the previous firmware and still experienced the problems so I invested quite a bit of time to try and stick with this expensive purchase but eventually had to cut my losses and put my old router back in.
Very disappointed.
TURBOGUARD
Mar 19, 2020Tutor
Haven't had the time nor energy to downgrade put them back up so still on RBK50. Netgear better fix this asap. It's not cheap (non-working) routers they're selling us!
- FURRYe38Mar 19, 2020Guru - Experienced User
Others are reporting better operation since NG seem to fix issues on there end.
TURBOGUARD wrote:Haven't had the time nor energy to downgrade put them back up so still on RBK50. Netgear better fix this asap. It's not cheap (non-working) routers they're selling us!
