Redlow
May 26, 2024Aspirant
Re: Major Firmware 7.2.6.31 issues
I am experiencing the same situation as you are on my RBR853. I am thinking of downloading 7.2.6.21 as I am out of ideas. (I was originally still on 4.x version, then upgraded a few weeks ago to 7.2...
Redlow
May 27, 2024Aspirant
FURRYe38 wrote:
Redlow wrote:Thanks FURRYe38
This size of home, the RBR and just 1 RBS would be and should be enough. IF you have two RBS deployed, try lowering the power on the RBR to 25% first.
Am I able to lower the Router separately from the Satellites? Last time I tried reducing the power I pretty much lost all camera access completely (and I only choose 50%)
Also, I just now disabled the 6Hz Wifi on the Bell router as well just to eliminate the possibility this is a factor. It did seem to have a small effect on the signal -- I am fluctuating now between -20 dBm and -32/-37 dBm... regardless, still experiencing cameras dropping and streaming dropping, so although it improved it, it didn't resolve it đ
Interesting though that the 6Ghz signal caused interference with the 2.4 Ghz signal.
