Redlow
May 26, 2024Aspirant
Re: Major Firmware 7.2.6.31 issues
I am experiencing the same situation as you are on my RBR853. I am thinking of downloading 7.2.6.21 as I am out of ideas. (I was originally still on 4.x version, then upgraded a few weeks ago to 7.2...
May 29, 2024Guru - Experienced User
What channels are you using currently on the Orbi system.
What channels are the close neighbors using?
Redlow
May 29, 2024Aspirant
FURRYe38 I am definitely on the good channel right now (Ch 1) and they are over on Ch 11. Here is the closest neighbor with the dLink router, and then the second has the rest of the wifi signals that show up.
- FURRYe38May 29, 2024Guru - Experienced User
Ok ya I use 1 and 40 on my main home network. While testing the other day the RBR was set for 11 and 48.
đ
