jglasse
Jun 02, 2024Follower
Re: Major Firmware 7.2.6.31 issues
I am having the same problem with my RBRE960 and two satellites. Before the update, it was reliable. Now the system randomly disconnects, every day. Sometimes rebooting just the main router fixes the...
Jun 02, 2024Guru - Experienced User
What disconnects? A wireless device? The RBR or RBS?
Does the front LED on the RBR turn PINK or WHITE when this happens?
Can you post the debug data seen there along with the Show Stats page from the RBR?
Take a screen capture please.
Router IP address/debug.htm
How often does this happen?
CAT6A STP is recommended between the RBR and ISP modem/ONT.
Is IPv6, SPC, Guest Network or Traffic Meter enabled?
Do you have the separate 6Ghz network enabled or disabled?
How are the RBS ethernet connected? Wireless or wired?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
