stig911t
Jun 05, 2024Aspirant
Re: Major Firmware 7.2.6.31 issues
Hello. I may have the same issue going on. I updated the firmware Friday night and the router has wen down at least 3 times since where it was previously stable for weeks/months at a time. Have you be...
Jun 05, 2024Guru - Experienced User
What model system do you have?
How was the system updated?
Does the front LED on the RBR turn PINK or WHITE when this happens?
Can you post the debug data seen there along with the Show Stats page from the RBR?
Take a screen capture please.
Router IP address/debug.htm
CAT6A STP is recommended between the RBR and ISP modem/ONT.
Is IPv6, SPC, Guest Network or Traffic Meter enabled?
Do you have the separate 6Ghz network enabled or disabled?
How are the RBS ethernet connected? Wireless or wired?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
