stig911t
Jun 05, 2024Aspirant
Re: Major Firmware 7.2.6.31 issues
Hello. I may have the same issue going on. I updated the firmware Friday night and the router has wen down at least 3 times since where it was previously stable for weeks/months at a time. Have you be...
stig911t
Jun 07, 2024Aspirant
I went back to V6.3.7.10_3.3.3 and thought I was safe but it rebooted last night. I did not do a reset after the firmware which is the next troubleshooting step I guess. You may want to try that before downgrading the firmware if you haven't yet. I was desperate to get it stable vs. troubleshooting the new firmware as it was dropping out in the middle of meetings/calls multiple times per day. I'll probably try a reset this weekend.
- FURRYe38Jun 07, 2024Guru - Experienced User
Try v.21 FW, RBS first, then RBR lastly.
You'll need to factory reset and setup from scratch after the system has been upgraded.
Please give feedback to the question presented.
