fIreChuckEr
Jun 07, 2024Aspirant
Re: Major Firmware 7.2.6.31 issues
Same issues. Never had an issue with the product until this firmware update. Constant drop-outs, and severe slow downs. Can I downgrade back to the previous firmware?
- Jun 11, 2024
Downgrading to 7.2.6.21 has been running a couple of days now, and seems to have worked.
Jun 07, 2024Guru - Experienced User
Try going back to v.21? RBS first, RBR lastly.
You'll need to factory reset and setup from scratch after downgrading.
- fIreChuckErJun 11, 2024Aspirant
- FURRYe38Jun 11, 2024Guru - Experienced User
OK, thanks for letting us know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
