ekiskyten
Apr 21, 2020Guide
Missing tile for security on orbi app
I just installed the orbi router. Yes, it is in router mode. I see no option on the router web admin for armor. I see no option on the orbi app for armor. The security tile is completely miss...
- Apr 21, 2020
I did chat with support, and they said new firmware will be coming out soon with support for Armor. I am happy for that, but not happy with all the time I spent trying to reinstall and configure everything based on the fact that all the documentation said support existed.
Apr 21, 2020Guru - Experienced User
Be sure your FW is up to date.
Factory reset the RBR and use a wire connected PC or laptop connected to the RBR. Walk thru the setup. At the end of the setup wizard, you should see a pop up message about Armor.
ekiskyten
Apr 21, 2020Guide
I did a factory reset.
I deleted and downloaded the orbi app.
I ran all the way through the install.
I never got a prompt for armor
:smileysad:
- FURRYe38Apr 21, 2020Guru - Experienced User
I would get in touch with NG support...
- ekiskytenApr 21, 2020Guide
Ok, thanks for letting us know. Ya, thought someone else reported having it on the 7 series. Were all curious about it coming to the 8 series as well.
Thanks for letting us know.
