Emilio142
Jul 30, 2024Follower
Re: My Orbi RBRE960 and RBRS960 network will sometimes just drop the wifi networks
I have the exact same problem. Used the set first in the regular router mode. Thought that the router mode was causing the problem as my internet provider uses a modem that cannot be set to bridge mod...
Jul 30, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
How are the RBS ethernet connected to the RBR? Using which ports on the RBR and RBS for the ethernet connection?
What is the brand and model# of the non managed switch in the mix?
What CAT# LAN cable is being used? CAT6A STP is recommended for 2.5Gb ports being used.
