RehanSaeed
Sep 29, 2021Aspirant
Netgear Orbi AX6000 - Open VPN Not Connecting While on Wifi
I have enabled DDNS and OpenVPN on my Netgear Orbi AX6000 and am able to use the Open VPN Android app to connect while on my mobile network. However, as soon as I connect to the WiFi, the app can no ...
Sep 29, 2021Guru - Experienced User
Turn OFF the RBS. Connect your mobile device to the RBR only and check.
Is Armor or IPv6 enabled on the RBR?
RehanSaeed
Sep 30, 2021Aspirant
Turned off the satelite router and that didn't help. I also had Armor and IPv6 enabled. When I also turned those off, that didn't help either.
- FURRYe38Sep 30, 2021Guru - Experienced User
I would open a support ticket with NG and let them know what your seeing.
- RehanSaeedOct 01, 2021Aspirant
According to the post below its not possible to connect to the Netgear routers Open VPN server while on the WiFi network. You can only do it from a separate network. Is this correct?
The problem is that I have to manually open the OpenVPN app and connect to my server every time I leave my home WiFi network. Is there a way to automatically get the OpenVPN client app to connect but only for the mobile network (I can't see a way). What is the best way to achieve automaticaly connect?
https://community.netgear.com/t5/Orbi/Orbi-OpenVPN/m-p/1282586/highlight/true#M6993
