palanzana
Nov 04, 2024Aspirant
Netgear Orbi RBR750 + Telecom FTTH problema VLAN SLOW
I read around that there are problems with these firmwares to use the vlan and connect the orbi directly to the ont...how do you solve it? the problem is only in wifi, don't ask me with which devi...
Nov 04, 2024Guru - Experienced User
Something to ask the ISP about. If they require a VLan Configuration, then they will have this information and should be able to help you configure a router for this. Orbi router use DHCP or PPPoE or Static IP address configurations along with DHCP Options 60 and 61 on some models to get connected to ISP services that may have any one of these particular configuration requirements.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
palanzana
- palanzanaNov 04, 2024Aspirant
the problem is only in wifi, don't ask me with which devices I do the tests, etc...before removing the TIM modem the Orbi router was working fine
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/RBR10-slow-internet-using-VLAN/td-p/2218996
