solarisfps
Jan 23, 2022Aspirant
Netgear RBR750 x2 backhaul/daisy still connecting via 5g
I live in a 3 bedroom house and i have the Orbi RBR 750 router and 2x satellite i have a cable running from my bedroom downstairs to the kids room to create a backhaul. Then there is a satellite in t...
solarisfps
Jan 28, 2022Aspirant
Nope they don't show being hardwired without the switch they are all still on 5g connection
SW_
Jan 28, 2022Prodigy
Did you connect Orbi LAN port to Sat's WAN port or LAN port?
- solarisfpsJan 28, 2022Aspirant
Satellites only have 2x ethernet ports so i dont think they are specefic ports for 1 duty.
I have the internet port connected to my virgin isp port so all is ok with the oreintation.
- plemansJan 28, 2022Guru - Experienced User
And how is the switch connected? Is it through the virgin gateway?
