MLUCK
Jun 29, 2022Star
Netgear Service is Horrible Horrible Horrible
I own two RBK750's, one each of two homes. For months now, neither has been manageable because I can't access the router either through the web interface nor the mobile app (iOS). So frustrating. ...
Jul 02, 2022Guru - Experienced User
So you'll need to factory reset and setup from scratch.
You'll need to save off a new back configuration to file. Always do this each time you make a change to the system. Never hurts to have too many backup configurations on file.
MLUCK
Jul 02, 2022Star
Factory reseting means spending days reconfiguring. But I guess I don't have a choice. So I've been sitting here all afternoon following Netgear's instructions to factory reset. I get the Amber LED after holding a paper clip into the reset hole for 10+ seconds, but then the router reboots with the same old SSID, not factory reset. Tried calling Netgear. They are worse than useless.
- CrimpOnJul 02, 2022Guru - Experienced User
Just to be clear, the Power LED turned amber and then began to flash?
- MLUCKJul 04, 2022Star
YES exactly - the LED turned Amber and then began to flash (pretty quickly)
- FURRYe38Jul 02, 2022Guru - Experienced User
Have 1 wired PC connected to the RBR. Turn OFF all RBS and disconnect ALL wired devices from the RBR. Disconnect the RBR from the ISP modem.
Press the reset button for 20 seconds then release.
Use a web browser and poing to 192.168.1.1...should bring up a setup wizard.
FURRYe38 wrote:Have 1 wired PC connected to the RBR. Turn OFF all RBS and disconnect ALL wired devices from the RBR. Disconnect the RBR from the ISP modem.
MLUCK wrote:Factory reseting means spending days reconfiguring. But I guess I don't have a choice. So I've been sitting here all afternoon following Netgear's instructions to factory reset. I get the Amber LED after holding a paper clip into the reset hole for 10+ seconds, but then the router reboots with the same old SSID, not factory reset. Tried calling Netgear. They are worse than useless
This worked, thank you. Why is it that you all are so helpful (and quick), yet Netgear support Is so slow and useless? Shocking to me.
One of my satellites is still showing as "Out of Sync" -- I've tried to sync a dozen-ish times. I've followed all the tips in the community, but no joy. Any ideas?
- CrimpOnJul 04, 2022Guru - Experienced User
MLUCK wrote:
One of my satellites is still showing as "Out of Sync" -- I've tried to sync a dozen-ish times. I've followed all the tips in the community, but no joy. Any ideas?Fortunately, doing a factory reset on a satellite is 'practically painless'.
- Power the satellite off so that in a few minutes it shows 'disconnected' and asks if you want to remove it.
- Remove it.
- Use the paperclip to factory reset the satellite when it is powered up again.
- Select the "Add Orbi Satellite" from the main web menu and add it.
My guess is that in the present condition, it is not possible to connect to the satellite web interface to determine which firmware the satellite has?
