Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
musicman0725
Mar 10, 2025Apprentice
I upgraded from V7.2.6.31. The only issue I had on that version is occasionally an iOS device (iPhone/iPad) would not be able to connect to the Orbi WiFi unless I toggled private wifi address on/off (it is recommended to have this setting off, but the issue would still happen, so the workaround is to flip it on and then turn it off later). So far I have not seen any devices run into this issue since updating.
