Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
Apr 21, 2025Guru - Experienced User
Have you tried a different setting for IPv6? Maybe Try 6to4 Tunnel?
Might be good to see if 6RD works for you if you sign up for Hurricane Electrics IPv6 service and see if this also fails.
I recently enabled it on a BE series system this past weekend for testing.
KMDonlon wrote:
Hopefully us IPv6 issue folks see an updated firmware fix soon đ
horustx
Apr 22, 2025Guide
I personally tried different combinations - IPv6 works for a few minutes then stops. Other routers and routers on older firmware did not have this problem.
Fortunately, I use VPN or Cloudflare WARP to get around this when I need to connect to my IPv6-only servers.
