horustx
Apr 04, 2025Guide
Re: New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
I have issues with IPv6 as well. I reboot the router, IPv6 works for a few minutes, then it stops again. This only started with this firmware. I brought a relative's Orbi (older firmware - forgot...
- Apr 06, 2025
I tried opening a ticket, and the system tells me I need to pay them to file the ticket.
Seriously? I need to pay Netgear to inform Netgear THEY messed up?
I posted on social media in a few places. If I don't hear back within a week, am escalating legally next.
This is unacceptable - a company remotely breaking a product you paid for, that was working fine, then asking you to PAY money to ask them to fix THEIR OWN mistake.
Maybe setting a court precedent will force companies like Netgear to take tickets for free, as well as make it (a lot) easier to downgrade firmware.
Apr 06, 2025Guru - Experienced User
Yes you'll need to downgrade the system back to v.21 or last working version. Also a factory reset and set up from scratch will be needed after downgrading the FW. Having a back up config file saved will help you get the system back online quicker.
You'll need to open a support ticket regarding IPv6 thats is broke on newer FW. Nothing we can do here to help. NG will need to fix that. NG doesn't post when new FW is forthcoming either. So you'll need to keep an eye on NGs download site or here in the forums.
This only started with this firmware. I brought a relative's Orbi (older firmware - forgot which one), IPv6 worked fine for hours, then upgrading it to this (latest) firmware broke IPv6 on that other Orbi as well.
I do not want to deal with downgrading and setting configs again - when will this be fixed Netgear?
- horustxApr 06, 2025Guide
- FURRYe38Apr 06, 2025Guru - Experienced User
Something you'll need to contact NG support about as all that is beyond forum help.
Take your complaint up with them.
