Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Aug 04, 2021Guru - Experienced User
For troubleshooting sake, yes, it's not recommended to use a back config initially.
Try a reset and setup from scratch. Try setting manual channel 1,6 or 11 on 2.4Ghz and 40 to 48 on the RBR.
I would set up the RBR first then bring the RBS to the same room as the RBR and sync them 1 at a time. Let us know if they don't sync and don't remain connected
Donsuper
Aug 05, 2021Star
After reset again, the satellite connect become unusable again, it’s for sure a firmware problem I think, factory reset and lab firmware upgrade again, still the same…..
No problem before update….
