Jul 12, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Atllaw
Aug 29, 2021Star
Or just buy something else without the problems. Or you can spend hours trying to figure out the problem and then return it in a couple of weeks. Wondered how many of these have been sent back to Amazon and Costco over the past month?
Timothy88
Aug 29, 2021Luminary
Netgear should be compensating us for all of this wasted time. What a terrible release, the develpoers and QC should be ashamed of themselves for a release this troublesome.
It’s a shame Apple got out of the router business.
- AtllawAug 29, 2021StarThe best I can see them offer is a year free support (which was worthless in this instance since they couldn’t fix it either) or some free Armor or Parental controls subscription for a period of time.
- Timothy88Aug 29, 2021Luminary
Yeah again both basically worthless.
- Renegade5150Aug 30, 2021TutorI’m in the same boat here. Wanting to trash this system and get a Ubiquity system instead. It’s too bad because up until this crappy firmware update things have been fairly fast and stable. Now my satellites keep flashing blue which means I have to reboot the entire system! Frustrating!!
- wjbridgeAug 30, 2021Star
Renegade5150 wrote:
I’m in the same boat here. Wanting to trash this system and get a Ubiquity system instead. It’s too bad because up until this crappy firmware update things have been fairly fast and stable. Now my satellites keep flashing blue which means I have to reboot the entire system! Frustrating!!I completely agree. I have achieved stability by downgrading the firmware on both Router and Satellite. I have to say NG has lost me as a customer for any future products. The only reason I am paining this out is that I cannot return it because I bought it through the NG website. I would love to put in a Ubiquity system. I wish they were not so expensive lol. Anybody have any experience with their AmpliFi routers?
- FURRYe38Aug 30, 2021Guru - Experienced User
Try this:
wjbridge wrote:
- jdk1120Aug 30, 2021ApprenticeHow/where did you find the old firmware, and how did you keep the system from auto updating to the current problematic one?
(apologies if this has been said before) - FURRYe38Aug 30, 2021Guru - Experienced User
All FW files are on NG download page for the 7 or 8 series systems.
How to prevent auto update:
(apologies if this has been said before) - Timothy88Sep 02, 2021Luminary
Well just as I figured, resetting to defaults was pointless as the router did the same thing again. Not good when your wife works from home and needs reliable internet. Thank you Netgear for releasing such a nightmarish headache of a release.
Any suggestions on a reliable replacement?
- FURRYe38Sep 02, 2021Guru - Experienced User
Did you happen to pull the power adapter for 1 full minute after doing a reset then plug back in then walk thru the setup wizard?
Something I happen to find yesterday with mine. I had done a reset on my RBR and RBS. Had all kinds of problems. I left the system unplugged and came back the next day. I was able to get the RBS synced correctly and the RBR setup well. I was able to get in to AP mode aswell. Been running ok since yesterday evening.
If v4 isn't working for you, I recommend you revert back to v3.
Timothy88 wrote:
Well just as I figured, resetting to defaults was pointless as the router did the same thing again. Not good when your wife works from home and needs reliable internet. Thank you Netgear for releasing such a nighmarish headache of a release.
Can an actual Netgear employee respond to this thread and acknowledge the issues and let the consumers that pay their salaries know when we can expect to see a release to address the problems?
Someting to open a support ticket with NG support and let them know.
https://www.netgear.com/support/#Good Luck.
How do you open a case without having to purchase support. Pretty good business model if you can't.
- Timothy88Sep 03, 2021Luminary
Sent a private message as you suggested. I'm sure it will fall on deaf ears as it seems larger companies/coroporations no longer care about consumer and their experience just their profit margin.
