Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes: Fixes security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. New Features and Enhancements: Supports Smart...
- Sep 13, 2021
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
Sep 20, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
ahswp wrote:
Netgear pushed the Beta to my 753s. Unfortunately, the push only went to my 750R not to my 2 753s. I manually upgraded the satalites and then turned the settings back to 100% for the 2.4 and other changes that had improved the problem.
I am STILL GETTING DISCONNECTS - the FIRMWARE DID NOTHING.
I continue to have issues with the satalite disconnecting.
NETGEAR IS THE WORST.
Maybe I should return these to Costco like so many others have.
Whats the point of pushing a firmware that doesn't go to the satalites AND also still has the same problem?
TSpoonEars
Sep 22, 2021Star
Last week we got the 4.6.3.16 forced update which messed up the DHCP table on the router. I had to walk my wife through resetting the table by telling the router the dhcp range was different as I’m working away. This worked until today when the same thing has happened overnight and resetting the table isn’t working, also while I’m working away. Was a new version pushed? I’m on sub revision 2_0_51 which seems later than last week. This is really frustrating as the system is quite expensive and at the moment it’s simply not working.
- FURRYe38Sep 22, 2021Guru - Experienced User
