Blanca_O
Oct 28, 2022NETGEAR Employee Retired
New - RBRE960 / RBSE960 Firmware Version 6.3.7.5 Released
Enhancements:
Improve the stability between base and satellite connections.
Improves satellite firmware upgrade stability.
Improves satellite ...
Nov 21, 2022Guru - Experienced User
I was told a long time about in Orbi 8 series days that NG found channel 40 worked best. Something I've been using since and haven't had any problems. They seem to recommend not using channel 36, I can't remember the details but they recommended avoiding 36, only used as last resort kind of thing. 44 and 48 are still good channels that can be used if 36 and 40 are congested or as a troubleshooting step.
DisneyFanatic4
Nov 24, 2022Tutor
Thanks, FURRYe38, for the additional information! I'll keep it on 40 as suggested.
