Mar 22, 2024Guru - Experienced User
New - RBRE960 / RBSE960 Firmware Version 7.2.6.31 Released
Enhancements: 03/22/2024
(For all regions except Europe)
Improves the stability of WiFi device connections during roaming
This firmware addresses security vulnerabilities. For more informatio...
- Jun 14, 2024
I have noticed issues that only seem to crop up after days of running - as few as 3-4 days, as many as 22 days. They are router or satellite restarts, memory growth in satellites to the point of causing a reboot and disconnect of all devices. I have seen WiFi disconnect and stop working until the router was rebooted. Have seen IPv6 stop working until it was re-enabled (likely a Comcast-NG interaction issue). I have seen satellites lose their backhaul connection with the router.
I believe at least the memory creep issues are related to using 2 satellites on Ethernet backhaul, just a guess. It could also be related to higher speed networks, mine is a 2G/200MB service. Maybe it's a combination of different factors that make the perfect storm that problems can appear? The % of Netgear customers with 2G and multiple Ethernet-wired backhaul satellites is small, I suspect. Plus, if there are some bugs that pop up after a number of days of running, NG has said that this kind of testing is very hard for them to do.
I just went back to v.21 to see how it runs. If v.31 is working well, great - if not, some caution could be warranted to try V.21 before spending lots of time trying to find a problem.
donawalt
Jul 22, 2024Mentor - Experienced User
I went back to V.21 and the satellites have been solid. I do see restarts on the RBS960 (two - after 6 and 22 days) - not frequent but annoying. I had restarts on V.31 as well, I agree with FURRYe38 that V.21 is more solid than V.31.
I have submitted lengthy reports on the bugs in V.31 - unchecked memory growth/leaks on the RBR and RBSs, hop count issues (RBSs lose connection to the router), and unplanned restarts. So I assume it is being worked on, I have been told Engineering is investigating.
liamscor
Jul 26, 2024Luminary
I have now also reverted to version “6.3.7.5,” which is definitely the most stable one for me, even more stable than “6.3.7.10".
Initially, I tried “7.2.6.21” before it was pulled for EU users, but unfortunately I encountered the same issues I ended up having with "7.2.6.31".
The satellites connections are now much more solid and robust, and the device connections are much more stable.
- TallrandalJul 31, 2024GuideRunning 7.2.6.31 now and I’m having major issues with Apple devices roaming. The devices stay connected to the furthest satellite even when a stronger signal is closer. Or sometimes the device just drops off all together and you have to cycle the actual WiFi off and on a few times. Does 6.3.7.5 seem stable for roaming? I also seem to be having a speed issue with my 2G Fiber, but that could be the service as they are new. Wireless device goes to 600 Mbps for a few seconds, then slowly drops to 400 Mbps and bounces up and down by a few 50 Mbps. Of course hardwire is a different story. I know WiFi is not as stable, but the WiFi on 7.2.6.31 seems to act funny. Then again I’m not sure if it’s my service or firmware.
Running RBRE960 with two satellites.- icehawk940Jul 31, 2024GuideWe have 3 iPhones and roaming was an issue on the newest firmware.. Since rolling back to 6.3.7.5 the connections are a lot more stable and roaming seems to work as expected. Also I did notice that a lot of devices were just bouncing around and not connecting to the closest satellite but 6.3.7.5 has solved that as well bottom line the older firmware seems alot better as I have been up without issues for close to 2 weeks now. I also have fiber.
- FURRYe38Aug 01, 2024Guru - Experienced User
What region are you located?
- TallrandalAug 08, 2024Guide
I too reverted to 6.3.7.5. Things do seem a lot more stable.
I also noticed my fiber speeds are better with .31 the speed tests would start out perfect and then tank by 300 Mbps and then go back up. I also noticed on .5 I have to restart every few days or else the internet seems to be unstable. Of course, I just wait for the kids to say something and then I restart. lol
The second issue I am seeing is a few of my new iPads are having issues connecting properly.
So, my new daily task is checking to see if there is new firmware. I have a feeling the wait is going to be a while..*sigh*
- FURRYe38Aug 08, 2024Guru - Experienced User
Had you performed a factory reset and setup from scratch after v.31 was loaded?
- TallrandalAug 08, 2024GuideI did several factory resets. I even tried .21. The roaming was a huge issue on .21. The ISP were also wonky too.
I am in the USA.
