atiq020
Jan 13, 2023Aspirant
New firmware for ORBI RBKE960
why we force to upload any new firmware Manually? we spend £1600 for these and not all are computer expert ? i heard download satellites first and then router and this is only possible when we do sa...
- Jan 13, 2023
There are some familiar sayings along the lines of....
"If it ain't broke, don't fix it."
"Fools rush in where Angels fear to tread."
In the normal course of things, new firmware appears on the Netgear support site well before customers become aware of it through either the Orbi 'app' or the Orbi web browser interface. There are some people who check the support site frequently and are eager to install the "latest and greatest". Far too often, posts begin appearing on the community forum that begin with...
I updated the firmware and NOW (something awful has happened). HELP!"Thus, many regular forum participants prefer to "wait and see". If their system appears to be working as it should, what do they gain by rushing to install new firmware?
For quite some time, Netgear had a practice of silently pushing new firmware to systems without notice. This caused huge turmoil when several firmware updates were botched in 2022, so the latest firmware for the AX systems introduced a new "feature": an option to disable automatic firmware updates.
I have never seen statistics, but it is abundantly clear that a significant number of customers pay no attention to what firmware is on their system. They never open the Orbi app or the web interface. (Why should they? They have work to do. Lives to live.)
I watched very closely when new firmware was announced for my old RBR50 in April of 2022. Neither the app nor the web interface detected it. After about a month, suddenly they said, "New firmware available." I ignored it. During the summer, one day I checked the router and it had updated during the night. Clearly enough time had gone by that Netgear decided the chances of something going wrong were minimal and "pulled the trigger."
On the new AX systems, if customers have not selected the option to prevent automatic firmware updates, then this is what is likely to happen to them.
It's your choice.
- "Damn the torpedoes. Full speed ahead. Let the fun begin."
- "Don't you touch MY system. I will decide when to update firmware. ME."
- "Do whatever you're going to do, Netgear."
Jan 13, 2023Guru - Experienced User
Mine have all automatically updated when I have it set that way and they're hardwired in.
I prefer to disable mine though. Reason why is when we see corrupt firmware on here its usually because someone updated over wifi or automatically. Its extremely rare to see someone with a corrupt firmware issue that did it manually.
To us it seems like a lot but its pretty rare to see the corrupt firmware issue. Its just seems like it because we're on the forums a lot.
atiq020
I agreed with you before when i am not join this forum i always update my FW automatically , since i seen this forum i bit confused.
so shall i try upload Automatically ? my both satellites are GOOD BH plz adivsed
- plemansJan 13, 2023Guru - Experienced User
If they're both working fine, I'd leave it.
Don't fix what isn't broken.
- atiq020Jan 13, 2023Aspirant
You mean "don't update the firmware?"
- CrimpOnJan 13, 2023Guru - Experienced User
It's your choice.
