Oct 23, 2019Guru - Experienced User
Re: New Netgear Orbi RBK852 Bugs
The Orbi AX supports ethernet back haul and works. Though the wireless back haul speed is slower than the 50 series. (2400 + 2400 + 1200Mbps) Not sure why they went with slower wrireless back hau...
I don't have one so just going off the spec sheets and my (poor) understanding.
so for the RBk50 series it has a 5ghz 1733 mpbs backhaul
the RBK852 series has a 5ghz 2400mbps backhaul is my understanding.
I think one of the releases had the incorrect information listed that the 1200mbps speed was the backhaul but its actually the 2.4ghz speed. Not the backhaul.
its listed correctly now under the system information.
No the back haul is spec'd out at 1200Mbps for some reason, The Primary 2.4 and 5Ghz radios that users devices connect to are spec'd at 2400Mbps.
