Oct 23, 2019Guru - Experienced User
Re: New Netgear Orbi RBK852 Bugs
The Orbi AX supports ethernet back haul and works. Though the wireless back haul speed is slower than the 50 series. (2400 + 2400 + 1200Mbps) Not sure why they went with slower wrireless back hau...
Wonder if the spec sheet is incorrect. I'll check into that.
Thinking about it, I believe that page maybe incorrect. If the model spec is AX6000, then thats 2400 + 2400 + 1200 = 6000. If it was 2400 x3 then that would be 7200.
I've seen 1900Mbps and upwards....
- FURRYe38Oct 23, 2019Guru - Experienced User
There a link to this page?
- plemansOct 23, 2019Guru - Experienced User
https://www.netgear.com/orbi/rbk852.aspx
its under the tech specs. just expand the triband wifi setup.
the 1200mbps is the 2.4ghz band. the 2400mbps is the 5ghz usable and 5ghz backhaul. Anandtech also goes over the 1200 mbps is the 2.4ghz, 2400mbps 5ghz, and 2400mbps 5ghz backhaul.
- plemansOct 23, 2019Guru - Experienced UserBtw I couldn't pull up the expanding options on my mobile phone. I had to be on a desktop.
