Infocynic's avatar
Infocynic
Nintendo switch won't connect to rbr750
I have looked through all the previous posts and updated my firmware, set cts to Max, disabled ax for 2.4 ghz (switch supports 5 ghz anyway), and disabled wmm for both 2.4 and 5 ghz. All the other dev...
  • Infocynic's avatar
    Infocynic
    Dec 23, 2021
    I just did a factory reset and it seems like it's ok now.
