Disturbd1
Dec 28, 2021Star
No devices connected through RBS750
I have the 2-pack CBR750/RBS750, purchased in 2020 when they were released. Firmware on CBR750 is latest - V4.6.5.8. Firmware on RBS750 is also latest - V4.6.5.14. For a few months now, I have no...
Dec 28, 2021Guru - Experienced User
Is the RBS directly connected to the CBR or is there a LAN switch in the middle?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Netgear has set up a community forum specifically for the Orbi With Cable Modem products:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
Disturbd1
Dec 28, 2021Star
FURRYe38 wrote:Is the RBS directly connected to the CBR or is there a LAN switch in the middle?
Thank you.
The RBS is connected to the CBR via the wifi backhaul (it's physically in my kitchen, whereas my CBR sits in my laundry room on the floor above. I have a LAN switch connected to the CBR directly, but nothing is connected via ethernet to the RBS.
My home size is just under 2k ft sq.
CBR and RBS are separated by being at the furthest 2 ends of the house (I'd say at lest 20-30ft) + they're separated by an entire floor.
I will try lowering transmit power of the CBR.
I don't perceive this to be an issue with the CBR; every device that connects to it works flawlessly. This exclusively an issue with devices preferring the CBR over the RBS regardless of range/signal strength, and so my first instinct was to at a minimum perform a reset on the RBS and reassociate with the network. I can't even do that effectively.
