Pony_Dus
Jun 13, 2022Aspirant
Orbi 6e stable wifi but no internet
Hi I have set up the newest rbk963 system with 6E and habe a stable wifi connection throughout. My cable modem is set to bridge mode and I am using the Orbi as a router. I have chosen unused wif...
Jun 14, 2022Guru - Experienced User
IS there a built in router at the modem by chance have built in router?
What is the connection rate supported on the Modem WAN port? 1Gb?
What CAT# LAN cable are you using between the modem and RBR?
What is the distance between the wired RBS and the RBR?
I would use channel 1, 6 or 11 on 2.4GHz. Not channel 3.
Pony_Dus
Jun 15, 2022Aspirant
- there is a built in router in the modem, which however is deactivated. also the LAN port is set to bridge mode, so no double IP issues
- 1 GB WAN port on the modem
- CAT6 1 GB/s LAN cable
-distance between RBR and wired RBS is approx.8m including a brick wall
- I have switched 2,.4 Ghz channel mode to Auto, and the RBR has chosen channel 9
Thank you
- FURRYe38Jun 15, 2022Guru - Experienced User
So do you get internet with the RBS turned OFF and services with just the RBR alone?
Wired and wireless?
- Pony_DusJun 15, 2022AspirantYes I do -
- FURRYe38Jun 16, 2022Guru - Experienced User
And now turn on 1 RBS and let it connect. Check the sync status on the 1 RBS to make sure it's GOOD with the RBR.
Set out at least 30 feet from the RBR.
Take one wireless mobile device and disable it's wifi radio. While near the RBS, enable the mobile devices wifi radio and it should connect to the RBS.
Check internet services here...
