Pony_Dus
Jun 13, 2022Aspirant
Orbi 6e stable wifi but no internet
Hi I have set up the newest rbk963 system with 6E and habe a stable wifi connection throughout. My cable modem is set to bridge mode and I am using the Orbi as a router. I have chosen unused wif...
Jun 16, 2022Guru - Experienced User
Would not be a FW issue, possible issue with the RBS itself. Something you should contact NG support about and have them check.
Pony_Dus
Jun 17, 2022Aspirant
Alrighty, thanks nonetheless
- jabenedicicJun 17, 2022Tutor
Sounds very similar to the issues I've been experiencing. I get more issues on wired devices than with wireless, but I do see the same behaviour you have described, good wifi connection and stable signal, just dead traffic.
I'm building a pfSense box today and going to stick the Orbi into AP mode and see how that helps. I am more than convinced there are some terrible software gremlins in these units.
- TC_in_MontanaJun 17, 2022Virtuoso
There are a couple of other users encountering some strange issues with their 960s. We are trying to track down/identify similarities (if there are) to see if we can help identify the issue(s).
Can you please check your Wireless settings via the WebUI and let us know if you have the "Enable 6GHz Only Network" under the 6GHz Wireless Settings section ENABLED (checked). Curious also as to whether you have this set up to the same SSID as your regular Orbi SSID or a different SSID.
Also - are you on a 1Gbps or better internet connection speed and can you please identify the Modem/Ont you are using for your internet connection.
Thanks!
- Pony_DusJun 17, 2022Aspirant
Thanks for confirming.... at least I now know I am not imagining things 😉
Let me know please if setting to AP changes anything
Hi
sure thing:
1) no, 6 GHZ is not set as "only", the box is UNCHECKED
2) my 2,4 and 5 Ghz bands are running on the same SSID
3) yes, I am on a 1 Gig ISP contract (Vodafone Germany, the ISP provided modem is a "Fritzbox Cable 6591" (pretty standard here in Germany)
Thank you, all help is appreciated
6 GHZ is enabled, but not as an "only network".
I am confused on your comment: "6 GHZ is enabled, but not as an "only network".".
So, does that mean you are using the 6GHz band on the main Orbi SSID and you do NOT have that option enabled?
Edited to add.... Sorry - I saw the 2nd reply, did NOT see the first reply.
I see you have the option UNCHECKED.
yes sorry 🙂
I am NOT USING a 6 GHz only setup, but 6 Ghz is enabled. (however I do not have 6 Ghz devices yet).
Okay - it seems like it is a different issue then. We are seeing a few people that have that option checked (see picture below) having issues with the 960 on a certain group of modems and high speed connections:
As long as you have this "UNCHECKED" - it appears to not be the same issue.
