Mastra11
Jun 29, 2022Apprentice
Orbi 753 automatically updated
Hello, I have an orbi RBK753 for months on routers and satellites I had the firmware version 4.6.3.16 which let's say it worked quite well for me, before without me doing anything the RBR750 router st...
- Jun 30, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
Mastra11
Thank you for the answer, unfortunately on these things it is only me who understands a little even if only the basic things I understand the more complex things no. I will let you know on this forum thank you so much.
Mastra11
Jun 30, 2022Apprentice
Hello I updated the satellites and routers, to version 4.6.8.5, first I updated one satellite then the other satellite and finally the router with the PC connected with an ethernet cable and Microsoft Edge everything was fine now routers and satellites have version 4.6.8.5 thank you for your kindness and your availability thank you.
- FURRYe38Jun 30, 2022Guru - Experienced User
Enjoy.
