GAMSAZAspirantJan 22, 2025Re: Orbi 770 Compatible Satellites Is it possible to use the Orbi 660 satellites with the Orbi 770?
FURRYe38Guru - Experienced UserJan 22, 2025https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
GAMSAZAspirant to FURRYe38Jan 23, 2025The list does not have the 770m and 660 on it so not able to tell unless I am not reading it correctly.
