GAMSAZAspirantJan 22, 2025Re: Orbi 770 Compatible Satellites Is it possible to use the Orbi 660 satellites with the Orbi 770?
GAMSAZAspirantJan 23, 2025The list does not have the 770m and 660 on it so not able to tell unless I am not reading it correctly.
FURRYe38Guru - Experienced User to GAMSAZJan 23, 2025The 770 is listed there. The 660 series is based off of 350 series Orbi model number. The 350 series is also listed there as well.
GAMSAZAspirant to FURRYe38Jan 23, 2025Thanks for the information.FURRYe38Guru - Experienced User to GAMSAZJan 23, 2025đ
