nal036
May 26, 2026Aspirant
Orbi 860 router, multiple satellites.
Weird, I have a similar issue. Orbi 860 router, multiple satellites. Only realised I couldn't log-on as some of my (UK) Sky TV Q mini boxes wouldn't connect this morning (all other wifi / de...
May 27, 2026Guru - Experienced User
Happen to know what FW version# is seen on the RBS web page?
If the web ui and orbi app are not getting connected to the RBR, you'll need to factory reset and setup from scratch.
Press the reset button in back of the RBS for 15 seconds then release then do same thing for the RBR. Give about 5 minutes for the RBS to auto connect to the RBRs default network before you start the setup routine.
Set up the system using a ethernet PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
FW may need to be updated...
