colst03
Jun 11, 2022Tutor
Orbi 960 - Maximum distance (outdoor no walls
Hello, What is the maximum distance between 2 Orbi 960 satellites ? Outdoor , direct view, no walls. Does rain affect ? Is same between Master and Satellite? What about 60 meters ? What max spee...
Jun 11, 2022Guru - Experienced User
No outdoor RBS.
Best recommendation for that kind of distance would be CAT6A buried LAN cable.
colst03
Jun 11, 2022Tutor
1) Outdoor : is it planned ?
2) so for 200 feet, I can forget ? Or would need. Another wifi solution ? Like Engenius? Because the cable is not an option đ
Thanks in advance.
Thanks in advance.
- FURRYe38Jun 11, 2022Guru - Experienced User
NG doesn't make it known if there going to make new products or not.
Might try this:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
