liamscor
Jan 30, 2025Luminary
Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks
Hello all, I’ve been investigating the device disconnect issues that many users have reported on this forum. After extensive testing of various wireless settings, I believe I’ve identified the...
- Jul 29, 2025
I have now managed to get round to testing this, and I can confirm that "Firmware Version 7.2.7.15" has fixed this issue for me.
Jul 29, 2025Guru - Experienced User
It it was just the application of the newer FW that resolved this for you then?
liamscor
Jul 29, 2025Luminary
Correct, I manually applied the new firmware, and then factory reset and setup from scratch.
- FURRYe38Jul 29, 2025Guru - Experienced User
Ok, thanks for the details. Glad it's working.
Enjoy. 📡
