Nobber1066
Jul 31, 2023Aspirant
Re Orbi 960 Black 2.4ghz re 5ghz separate or Shared SSID
Hello is it better to have one SSID with 2.4 and 5 or should I split out the 2.4 and put it on a different SSID Thank you Nobber
- Jul 31, 2023
What the IoT network is for.
Jul 31, 2023Guru - Experienced User
The main WLAN on the Orbi can't be separated. There is the IoT network for each frequency however if you need separate SSIDs.
