Nobber1066's avatar
Nobber1066
Re Orbi 960 Black 2.4ghz re 5ghz separate or Shared SSID
Hello is it better to have one SSID with 2.4 and 5 or should I split out the 2.4 and put it on a different SSID Thank you Nobber
  • FURRYe38's avatar
    What the IoT network is for.
