MikeG63
Sep 13, 2024Apprentice
Orbi 960 working with BT Internet
Are any U.K. members of the community familiar with the Orbi 960 series working in conjunction with BT Internet. My trusty Orbi RBK53 was damaged by a lightning strike in our road and previous to the ...
Sep 13, 2024Guru - Experienced User
If you had a modem prior working with the RBR50, then I presume a modem maybe needed. For a ANY router to work with out the modem, something needs asking with the ISP.
MikeG63
That was the debate I had with the BT Engineer, however as I previously stated, and the reason for my reaching out the Forum, he said the VDSL modem I have is obsolete and modern routers should just plug into the internet socket on the master socket. I am in doubt that this will work, and before I spend £1699.99 on a new router I wanted to be sure as I am still not convinced that it’s not the modem at fault.
Have you ever had a sensible conversation with a BT Support Engineer off shore!!!!
- CrimpOnSep 13, 2024Guru - Experienced User
Have you tried plugging the RBR50 into this "socket"?
- MikeG63Sep 14, 2024ApprenticeYes I have, and it doesn’t work. So I’m left wondering a) is it the modem, b) is it the router because it’s an older unit, or do I need a new BT modem that works with the new master socket and I turn the wireless off!!!
Anyway I’ve bought a replacement modem for £22.00 off eBay to hopefully eliminate that possibility. If that doesn’t improve matters I’ll buy a refurbished / replacement RBR50 from eBay and see if that’s the route cause and go from there!- FURRYe38Sep 14, 2024Guru - Experienced User
Sounds like a ISP modem is needed to bridge the gap between the ISP services and any router you choose to put online.
