Spezaled
Apr 07, 2020Tutor
Orbi AX 6000 and AT&T fiber gateway issue
I recently purchased the Orbi with WIFI 6 and planned on using them in AP mode to extend my U-verse Fiber gateway modem signal. Got the WiFi set up just fine but now my U-verse TV signal locks up afte...
- Apr 09, 2020So AT&T came out and configured the gateway so that it all works now. They kept the tv feeds going to the gateway, set it to IP pass through and turned off he WiFi. The Orbi had to be set to router mode, not AP mode because of an IP conflict. Everything is running again.
Apr 09, 2020Guru - Experienced User
Yes, NAT is still present on ATT Modems. Since they don't support full modem mode.
DoctorA wrote:Will NAT be still present there even though NAT server is switched to OFF here in this menu?
Attached is the screen shot of my ATT menu
DoctorA
Apr 09, 2020Luminary
I wonder how much this NAT presence is affecting the overall performance of the system. I don't have any problems right now with 40+ devices but with more devices in the future, If the difference becomes significant, then bypassing ATT Router by Dumb switch method, by spoofing the MAC of the Router on Orbi, is an attractive alternative.
