Spezaled
Apr 07, 2020Tutor
Orbi AX 6000 and AT&T fiber gateway issue
I recently purchased the Orbi with WIFI 6 and planned on using them in AP mode to extend my U-verse Fiber gateway modem signal. Got the WiFi set up just fine but now my U-verse TV signal locks up afte...
- Apr 09, 2020So AT&T came out and configured the gateway so that it all works now. They kept the tv feeds going to the gateway, set it to IP pass through and turned off he WiFi. The Orbi had to be set to router mode, not AP mode because of an IP conflict. Everything is running again.
Apr 08, 2020Guru - Experienced User
Is there more details on this switch method that you can share for us?
Retired_Member wrote:I have AT&T Fiber gigabit internet. I use the "dumb switch bypass method." It works excellent! However, it requires some IT knowledge. I completely have my AT&T gateway in the drawer, powered off. I'm using the RBK852 as my only gateway.
Jce1984
Apr 19, 2020Aspirant
https://community.netgear.com/t5/user/viewprofilepage/user-id/255615
Are you using att modem gateway at all or using your own modem or does bypass only work for using your own router
