Rudolphy
Jun 28, 2021Apprentice
Orbi AX Wifi 6 AC 4200 - Backhaul status
Dear all, one question regarding backhaul satus for ax-satellites: What does "out of sync" mean? This status appears approx. every 2 hours. I only know "config sys" from my former ac-devices. I ...
- Jul 03, 2021
I think I solved the problem by changing my setup. So far I had a RBR750 and 2 RBS750 and in one room an EX8000 repeater as an access point. On the satellite where the EX 8000 was wirelessly connected, the backhaul status was "out of synch". When I replaced the EX 8000 with a third RBS750, this message no longer appeared.
The system has been stable for three days now.
Strange, but it seems that the EX 8000 was to blame. The EX 8000 is also on the latest firmware
Jun 28, 2021Guru - Experienced User
Try swapping locations with the other RBS.
Solid brick or concrete will impact wifi signals.
Try the reset of the RBS while the RBS is in same room as the RBR and check it's status...
Rudolphy
Jul 03, 2021Apprentice
- FURRYe38Jul 03, 2021Guru - Experienced User
Good to hear. Sounds like the EX may have wandered to a different signal or something. Glad you got it working well.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
