sen4ik
Oct 22, 2021Guide
ORBI CBR750 requires manually releasing/renewing the IP
I have Netgear Orbi CBR750 with RBS750 satellite. I own this for two month now. Four days ago, it started dropping internet every 1.5 hours. Rebooting the router would bring the internet back. I ...
Mar 28, 2022Guru - Experienced User
No, you have the CBK750 system which includes the CBR and RBS. All of which have a separate forum for. Please post there.
The CBK and RBK are two different systems.
Please contact NG support and let them know what your experiencing as any fixes will need to come from NG.
https://my.netgear.com/support/contact.aspx
There's nothing here in the forums we can do in regards to that.
Thank you.
atejwani wrote:
There are clearly issues with
- CBR750
- RBS750 (Does my thread not belong here)?
Secondly, the only solution I can think of is the firmware fix by Netgear - none of the hacks/tweaks work - they rather cripple capabilities.
