Cdhappz
Jan 16, 2022Aspirant
Orbi cbr750 wifi disconnect/reconnect
So after the new firmware the speed tests have increased back to normal speeds. I however was experiencing a separate issue. My internet was still unstable. Meaning randomly I would get a connected bu...
Jan 17, 2022Guru - Experienced User
What samsung tv is it?
Cdhappz
Jan 17, 2022Aspirant
Samsung - 32" Class N5300 Series LED Full HD Smart Tizen TV. It is a 2018 model and samsung has stated like in the screenshot I shared from their own forum it will connect to the 5ghz network even though it needs 2.4ghz to function properly. It's a major failing on samsungs end and should be addressed. I just wanted others possibly having issues to be aware of this as a possibility.
