MdSazzad
Apr 12, 2024Follower
Re: ORBI Change satellite password
I have an Orbi satelite rbs 750. It's connected to a main router. Now the issue is I cannot log into the satellite and change it's password. We're using the default SSID and wifi password that are wri...
Apr 14, 2024Guru - Experienced User
All Orbi RBS get there log in credentials from the RBR during the wireless sync process. You can not change the RBS credentials. RBS use what ever you set for the RBR.
Be sure all RBS and RBR firmware is at same level across all units.
MdSazzad wrote:
I have an Orbi satelite rbs 750. It's connected to a main router. Now the issue is I cannot log into the satellite and change it's password. We're using the default SSID and wifi password that are written under the bottom side of the satellite. If it's meant to be use router's password why isn’t it using it? We can access the internet but what bothering us is that we can't change the password. I've tried everything like orbilogin.com, orbilogin.net, http://192.168.1.1 and http://10.0.0.1 but nothing seems to be working.
