Mar 09, 2020Guru - Experienced User
Orbi Firmware v3.2.10.11 seen on your RBRs FW update check page?
Just curious if anyone out here in the public forum are seeing this version pop up as available on there RBRs web page? IF so, please post what version of FW you currently have loaded. Up to y...
- Mar 20, 2020
Problems seen on v10.11 since 3/9 have been addresses and fixed by NG. They reported that it was something having to do with there cloud systems. v10.11 FW was put back up on there auto update servers for users to download as of 3/19. These problems have been resolved.
If users are noticing any futher problems please make a new post about it or contact NG support.
Enjoy.
Mar 10, 2020Guru - Experienced User
For those of you experiencing problems after v11. FW was loaded yesterday. Can one or two of you experiencing this problem while in router mode, set up and enable capture WAN and LAN and Debug logs for a short while or however long it takes for you to see the problem appear.
Open a web browser to http://192.168.1.1/debug.htm in a web browser will bring you to the RBRs debug page. Check mark each of these two options and then begin normal use. When you notice the problem. Go back in to the debug page and select capture logs button. This will download the logs from the RBR and send them to your default browser download location. If you can upload this .zip file to a drop box or cloud file service then share the download link, we can get this to NG for them to review and hopefully help them figure out whats going on with those of you who are seeing this problem. Hopefully this will help narrow down where the problem maybe in FW. Still odd that some of us are not seeing this. Hopefully NG can pin point it. :smileyfrustrated:
Thank you for your time.
xnolightx
Mar 10, 2020Star
I would be happy to, but I actually had to pull my system down entirely and replace it with my previous Google Wifi system. I'm in the middle of planning for a product release and I won't have the time over the next couple of days to put the system back up.
What seemed to bewilder me about this is that even after reverting back to 3.2.9.1_2.4 I had the very same issues. I'm confident that I did not start seeing this issue until 3.2.11 was released, but now my system is completely toast. I'm truly scratching my head over this one, but I agree logs should help NG sort this out.
Has anyone else reverted firmware, and if so are you still seeing the issues like I am seeing?
