MSS37448
Oct 26, 2020Aspirant
Orbi RBK 853 and Orbi Pro
Hi, I am based in the UK and live in a "large house", which suffers from poor WiFi and WiFi dead spots. I am considering investing in a WiFi 6 Network System, as there at least 30 devices on t...
Nov 04, 2020Guru - Experienced User
Good Luck.
MSS37448
Nov 04, 2020Aspirant
Hi FURRYe38,
Would you know if I can use Orbi RBK 853 with my ISP Router, by just turning the WiFI Radio off [i.e. do not switch the ISP Router into Modem Mode}. Would this work and are there ny drawbacks with this approach?
Thank you for yiour help and patience.
- FURRYe38Nov 04, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- FURRYe38Nov 04, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
