akhilstyle
Jul 29, 2022Tutor
ORBI RBK753 No Connected Orbi Ethernet Backhaul
Hi, I have my RBR connected to some satellites. All of the the Satellites are connected directly to the RBR via ethernet without any switches in between. I have noticed that one of them occas...
akhilstyle
Oct 31, 2022Tutor
Hi,
Thanks for the reply.
The sky booster is for my sky q TV box. It is connected to a switch and connects my sky q TV boxes to each other via a hidden network separate to the Orbi. I disconnected this and had the same problem with the phones not getting an IP address occasionally for a few minutes. After about 5 minutes I finally get an IP address.
I have also connected the satellites to the router with Cat 6 to test this out - but getting the same issue (however I am not noticing this "connected orbi" issue with the cat 6)
ekhalil
Oct 31, 2022Master
If there are devices causing IP loops, then disconnecting those devices does not immediately solve the problem, it will take time for the system to stabilize. Does the problem happen again if you keep the sky booster disconnected?
